Hey 2000 ford ranger
jackson1966
South carolina
Hey I have a 2000 ford ranger flex fuel every morning I have to start my truck like 5 to 6 times before it started I have pretty much replace all the sensors and 02 sensors under the hood but I check the fuel pressure and I have none after it sets over nite and it has a new fuel pump on it after it cracks it runs fine after about 8 hrs it leaks down it has no fuel pressure regulator on it no were I did read some that it suppose to be on the fuel pump just wondering if any one else every had this problem thanks in advance
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
As a temporary fix, turn the key to on for 2 seconds about 5 times (without starting the truck). Each time the key turns on, the pump puts in about 10psi into the fuel lines. Iirc your system needs minimum 50 to start, and should be 60-70.
