high amp alternators
Will
514
Gnaw Bone, Indiana
Toyota
Your personal vehicle modifications are obviously not subject to the National Electric Code, but...
according to NEC regulations on Allow Ampacities of Single Insulated Conductors rated 0-2000V in Free air, a current of 130A requires a 4 gauge wire with 90°C insulation (it's good up to 140A). For 60° insulation you'd need 2 AWG and 75° insulation would require 3. The insulation class is usually printed on the insulation.
Not saying your wire is going to melt the second you turn your lights on, and there are obviously more than a few that have used 8 AWG, but if the NEC considers it unsafe to use any less in a house or other building, then it's probably for a good reason.
The FAA has a similar view. Theis is an article I did for our mag 5 years ago. Controlling the lights on several circuits is the thing to do or course. On my truck I have a panel made by Blue Sea and everything I added runs to it. I don't have stadium lights--or any aftermarket lights, but if I did, I would have each pair switchable through it.
LittleHorse
Pryor, OK
2.9L
definitely.
I was actually referring to the alternator wire with that post, but I apply the same rules to any wiring I do.
I don't have lights yet, but I am in the process of installing 1200W worth of audio and you can bet I'll be following NEC wiring rules to the T. If I add lights I imagine I'll probably upgrade to the 130A alternator.
My BII carries liability insurance only, I can't afford to watch it burn to the ground. :bawling:
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Try what you have and see how it works out.
If the you have problems or signs of problems get the 130 amp unit.
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
i've had an Optima knock-off (Orbital) Yellow Top for 2 years now without any problems at all. running fog lights, driving lights, off-road lights, 12v compressor, etc. coldest it got here this winter was -32 and my truck started right up, no problems. the truck does have a block heater, but that doesn't do much for the battery. i think it's great.
