Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Well since you didn't put you rig info in either the sidebar or a signature we'll have to guess. 1. The dimmer switch is bad. 2. The main fuse box under the hood may have a low beam headlight fuse that's blown. 3. Also bad bulbs but those are Vegas odds that they'd both blow the low beam filament at the same time.I searched the posts a bit and didnt find any thing similar to my problem. MY high beams work but my low beams do not. any ideas?
Yep. Sorry. I was distracted. It's almost like yours. 94 2.3 with the a4ld.Well since you didn't put you rig info in either the sidebar or a signature we'll have to guess. 1. The dimmer switch is bad. 2. The main fuse box under the hood may have a low beam headlight fuse that's blown. 3. Also bad bulbs but those are Vegas odds that they'd both blow the low beam filament at the same time.
The problem is if we don't know what you own & drive we have to generalize our answers.
Not nessiscarly ecause my friends had both lows working after we fiddles with the plugs in the dash column.the bulbs are bad. i saw this 1000 times during my autozone days. go get new bulbs and put them in and i bet they'll work
