Rollin
- Oct 1, 2009
- 0
- Ford
- Engine Size
- 4.0L
Have you tried setting the idle like this,
Originally Posted by ransil
Idle reset procedure.
1. Unplug the SPOUT connector, start the engine and let it reach operating temperature, then check and, if necessary, adjust base timing.
2. Shut the engine down, then stick a .050-inch feeler gauge between the throttle stop screw and lever.
3. Disconnect the IAC solenoid connector, shift the transmission into Park, start the engine and allow it to stabilize for approximately two minutes.
4. Adjust the throttle stop screw as necessary to obtain an idle speed of 675 rpm 25 rpm.
5. Shut the engine down once again, then disconnect the battery for a minimum of five minutes to allow the PCM's keep-alive memory to time out.
6. Remove the feeler gauge, reconnect the SPOUT and IAC solenoid connectors, then start the engine and allow it to stabilize for two minutes.
7. Goose the throttle several times, let the engine return to idle, then make sure the base idle speed remains in spec.
8.Drive it for 15 minutes making frequent stops.
Is this the same procedure for all ford mass air EFI engines??
Thanks
Thanks
