Horn Stuck On 2019 Ranger
matteroffact
Reno NV
Ford Ranger FX4
2.3 EcoBoost
Hit a small speed bump and my horn has stuck on. This happened one other time while off roading but it turned off after a bit that time. Unfortunately this time it will not turn and I had to pull the fuse.
I took off the airbag and the horn switch/clockspring on the steering wheel seem to be fine.
The horn relay makes a click on/off when I press the horn, and same if I swap the relay with the one next to it in the fuse box.
I took the bumper off the get to the horns, and the wire that connects the horns to the harness has a solid 12v no matter the position of the horn relay (on or off). The wire also has 12v if the relay is removed from the fuse box.
What should I try next to fix the horn?
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,818
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Sounds like the horn may work by grounding it when you press the switch instead of applying power.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Haha your truck is horny.
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The horn is connected to a constant ground source. It comes on when the horn switch sends a ground signal the BCM. The BCM then pulls the horn relay coil to ground to activate the relay. Power is then sent to the horn.
I you can pull the horn relay from the panel and you still have 12 volts at the horn... the horn wire is shorted to battery positive.
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Most likely culprit would be a short in the battery junction block or a short in the wire bundle near the junction block.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Is there some sort of override or another power source possibly from a different controller for the panic function on the key fob? Or security feature.
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It would have to be an aftermarket control. The BCM handles all that by the looks of things.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
We've come a LONG way
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I'd listen to Uncle Gump. He seems to be quite savvy with horns and groundings....perhaps also horny...
8,373
If pulling the Horn Relay doesn't cut off the 12v to the horn but pulling fuse 48(20amp) does, then fuse 48 is getting 12v when it shouldn't
So fuse box short circuit to fuse 48 between relay and fuse
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
or perhaps well grounded . . .
I'll see myself to the corner.
I know what I did.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I know what I did.
The old 3rd leg joke eh? Well played sir.
I am also in the corner.
Your gun is digging into my hip.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That isn't his gun...
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I think RonD has it... There's probably not a lot of wiring length to look over since it looks like both the fuse socket and relay socket are right there in the battery junction box.
Any electrical mods to the truck? (aftermarket lights, switch pods, etc.)?
