HotRodRanger96
- Aug 10, 2021
- 1
- Mannford Ok
- Ford ranger
Hello all I have a 96 ranger 2.3 5 speed stepside and my idea is to take the fuel injected 2.3 that's in it change the head gasket to a Cometic MLS with a compressed thickness of .018-.027 should up the compression a little next polishe and smooth out the intake and exhaust ports for better flow and change out the cam sprocket to an adjustable one all while I got the head off then fab up a cold air intake out of some 4 inch tubing next redo the exhaust take out the cat install a Flowmaster 40 or 60 series muffler and install either 2 or 2.5 inch exhast pipe exiting in front of or behind the passenger rear tire. I heard blocking off the egr will gain you some mpgs so let's block it off. Upgrade the ignition coil, wires, and plugs possibly look into polishing and smoothing the intake manifold all of this to get as much hp and fuel mileage as I can before pulling the 96 2.3 engine and replace it with a full on carbureted race engine. Stupid idea? Cool idea? Why the hell? What's your opinions comments or criticisms. Knowledge is king
