How can i fit Super Swamper LTB 33x13.5x15
mr_speed77
I have a 93 4x4 4.0 gonna put a rough country 4" suspension lift. Can i fit these with trimming? Wheel spacers?
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
you wont need to do any trimming to fit those tires with 4 inches of lift. they should clear fine without wheelspacers.
rickcdewitt
5
nor-cal
4-0 swap
depending on your wheels they might rub the sway bar and shocks.
mr_speed77
well im going to buy new wheels with it the steel pro comps just cheapies. What should i get? Would i be able to fit these with a 3" body lift instead of a suspension?
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
you could but a suspension lift is preferable because it actually gives you more ground clearance.
mr_speed77
knew there had to be a reason the body lift is cheap. So what rims should i get to be able to clear the 13.5 wide without rubbing too much?
rickcdewitt
5
nor-cal
4-0 swap
3.75" backspace is about right.they say to run a 10" wide wheel with the 13.5 ltb but a 8" or 9"if you could find it might work.
86ford
rocky river ohio
FORD
4.0, abused and misunderstood
you shouldent run a 13.5 inch tire on any rim less than 10 inches wide. you have to ajust your backspacing to keep from rubbing, i dont know the magic number for backspacing but i think 3.5-4 is the range you are looking at. you can call one of the 4wheelparts stores and they can better guide you because they awnser these qestions daily. you mite rub your fenders at full flex wheeling but wont have problems on the road if you get the 4 inch suspension lift.
86
