How in the name of god do you remove the flywheel?
BudgetB3000
Pullman, WA
Mazda
I'm currently doing a clutch job on my truck and I cannot remove this god damned flywheel. I've been spraying the bolts down daily and taking a breaker bar to them but its virtually impossible to do since the flywheel spins freely. Normally I would just put a second breaker bar on the front of the crankshaft but on the 3.0 engine there is not enough clearance with the engine in the car to do so. Any suggestions on how to get this done?
BlackBII
Ranger Custom
Truck of Month
982
UT
I usually use an electric impact. The DeWalt one I have will spin them right off. If you don't have access to an impact, you'll need to use a flywheel locking tool. They usually have a prong that locks in the teeth and you hold that to keep it from spinning. You can rent them from AutoZone/O'Reilly.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Junk Collector
Truck of Month
4,821
Rapid City SD
You absolutely need some sort of impact tool, or you need a helper to hold the other end of the crankshaft still - a socket and breaker bar on the front pulley will be fine. Wedge it against the frame if you don't have a helper. The flywheel bolts are NOT super tight, you're just going at the process the wrong way.
:icon_rofl:
fastpakr
2,838
Roanoke, VA
Worst case, pull the fan and shroud to get some wrench clearance up front.
17,907
SW Iowa
Deepwell socket and breaker bar to the frame rail works great for me. :icon_thumby:
Be sure you don't forget about it after installation. :icon_idea:
BudgetB3000
Pullman, WA
Mazda
All my room mates are out of town this weekend so I don’t have anyone who can hold on to the crank right now so I’ll have to find a place to let me rent an impact wrench. Thanks everyone.
fastpakr
2,838
Roanoke, VA
Harbor freight sells a cheap corded impact wrench that would be perfect for the job.
BudgetB3000
Pullman, WA
Mazda
I may have to do this as my local auto parts stores do not rent impact wrenches or the flywheel tool that was mentioned in this thread
Junk Collector
Truck of Month
4,821
Rapid City SD
You don't need much. I have a 1/2 DeWalt 18v impact (the small one, not the big high torque model) that will zip them right out. Maybe hit up a pawn shop or something... impact is a handy tool to have
fastpakr
2,838
Roanoke, VA
17,907
SW Iowa
Just let the breaker bar on the front of the engine come against a frame rail. Works great.
You can impact them off but you should torque them going back together, either way you are going to need a breaker bar.
17,907
SW Iowa
