How much coolant does a 2008 ranger take?
Infamouscanadian
Calagary
Ford ranger
I’m looking to change my upper rad hose, and I need to drain then fill the rad. How much fluid should I get? Thanks
Well ideally you would catch said coolant and reuse it, or at least not let it into the water table. To just do the upper hose you only need to drain a little bit.
If you want to change it you are looking at about 2 gallons.
Infamouscanadian
Calagary
Ford ranger
Oh ok, how much would you say I should drain?
ericbphoto
Overlander in development
16,684
Wellford, SC
6"
I know this isn’t ecologically correct. But for upper hose, I just take it off. Coolant will automatically drain to the necessary level. Install new hose and refill system.
Infamouscanadian
Calagary
Ford ranger
How do you know how much coolant to put back in?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Until it's full?
ericbphoto
16,684
Wellford, SC
6"
What he ^^^ said. Fill the radiator. With radiator cap off, start the engine. In about 8-10 minutes, the thermostat will open. At that point that pump will fill your new hose and you will see the level in the radiator drop. Add until the radiator is full and install the cap.
When finished, hose down the entire area where you spilled coolant. This will dilute and wash away the coolant so animals won’t drink it and get sick. The coolant is biodegradable and will be harmless to the environment in less than two weeks. Problem solved.
Infamouscanadian
Calagary
Ford ranger
Ok thanks guys, so I don’t have to empty out all the coolant when I’m replacing the hose? How do I know how much to empty out? Sorry for the noob questions, I’ve never worked on my own vehicle before
ericbphoto
16,684
Wellford, SC
6"
524.386 ml. Exactly
Using the draincock on the bottom of the radiator drain it until you can't see the coolant from the fill port on the radiator (the hole that the cap closes), into a clean drain pan.
Put in what you took out. This more than anything is the reason to catch it as you take it out. As was said earlier, coolant these days IS biodegradable.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
@adsm08 how will he know when enough has been drained, to put back in, if he is at the bottom of the radiator
This is one of those times that close enough is usually close enough.
Mike Tonon
Guest
I found that my 07 4.0 takes just over 2 gallons. So either reuse some of the old coolant or plan on buying more than one gallon. And only use distilled water, not tap water.
