Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
okay, i am going to use the red terminal connections.... says for 22-16 gauge, also have blue for 16-14, and yellow for 12-10step 5 if you have to fold it in half you have the wrong size terminal, if you can fold it in half and still stick the wire in there the wire/terminal is the wrong size
i dont know about 'end of story'. i dont think 12 volts is enough to do any major damage. ive burned myself a few times, but thats about it.Yea, it can it can supply voltage to you, subs amps cars can all be replaced. If you get zapped end of story. And that's why I do it, but to each his own and this is a pita on an iPhone in traffic
but when you remove the negative your creating a open circuit. unless your messing with a power wire straight from the battery, no damage can be done.
and clip it on an unpainted piece of metal?just remove the negative terminal. dont let it touch the negative battery terminal. otherwise good luck with your install.
okay thanks... gonna go get startedno need to clip it on anything. i know when i take mine off, i slide it on the side of the battery.
where the metal part of the terminal part that i bought connects to the termal on the actual speaker was a bit insecure...i dont understand what you taped. if you wrapped some tape around where you crimped the female quick disconnect and the speaker wire, then i guess thats fine. there shouldnt have been any exposed wire once you crimped it though. otherwise you stripped too much of hte jacket off. or do you mean that the quick disconnect didnt have a snug fit over the speaker terminal? if you used the correct size but its loose, use some pliers to close the quick disconnect a little so it fits tighter.
I see what you mean from the pics in your photo bucket. The wire crimp is too big for the speaker terminal since one is larger than the other. I am suprised your new speaker didn't come with the approperiate wire already with the fittings pre-crimped for the speaker terminal. The only way I can think of to fix it well is to get a smaller crimp for the wire that fits the terminal.where the metal part of the terminal part that i bought connects to the termal on the actual speaker was a bit insecure...
i will plier it to squeeze around the connector on the speaker better.. didn't know if i could do that or not.
i couldn't find any smaller terminal endings at lowe's... but yes, now that i know how to get everything apart it shouldn't be such a big deal to replace them down the road.I see what you mean from the pics in your photo bucket. The wire crimp is too big for the speaker terminal since one is larger than the other. I am suprised your new speaker didn't come with the approperiate wire already with the fittings pre-crimped for the speaker terminal. The only way I can think of to fix it well is to get a smaller crimp for the wire that fits the terminal.
I imagine that smashing it a little and use of tape may suffice as a band-aid for the time being, but over time I would suspect that it may cause an issue later on due to vibrations and such. Smashing is also risking that the metal gives and then it won't want to stay on at all. Your call on that one, I am sure someone else may have some other ideas. Since you got it out at this point; say 3 years down the road it will be a piece of cake to take it apart again if it does become problematic (like intermittently working).
I am also kind of curious on how you went about getting them back into the dash since the speakers appear to be 4 mount style(?).
Pete
Edit:
And I just noticed that speakers have some depth to them. Should be alright, just watch that a little - might hit the plastic heater tube on the driver's side.
welcome to the world of custom fabrication lol, what are they gonna hit on?never thought about the depth, but i checked, without the dash just eyeballing it kinda, and i don't think the drivers side will fit. didn't check the passengers side though.
wtf am i gonna do... i know this is prob my fault, i just figured that depth wouldn't be a big deal.
