How to reliably lift 05 ranger torsion bar by 2 inches?
Schiky
Hey guys, I'm going to need to lift my front end by 2 inches, is there a safe and right way to do this? I want it to be reliable and not have any detrimental effects on other front end components. I've had a number of people tell me to just crank up the torsion bars and it'll be fine and give me the lift I need. However other people are telling me that if I do that then I'll trash my ball joints and bearings. Does anybody have any ideas? I can't even find any kits or anything for 2 inch lift in the front besides torsion keys. What do you guys think? Any advice or ideas? It's a 2005 Ford Ranger XLT 4x4 with the Torsion bar front suspension and custom built leafs in the rear.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Crank the front and run the longer rancho part #RS5374 shocks to accommodate the difference in suspension height.
It is as reliable as you are going to get without going to a full on super lift kit for 4" of lift.
gw33gp
540
Costa Mesa, CA
4.0 SOHC
33"
I can tell you I have run my 02 Ranger for 175K miles with a 1.5" torsion bar lift and haven't had any problems with the suspension or drive axles. It still has the original ball joints but the top ones are due for a replacement.
Another 1/2" lift may cause more wear but should not be that bad. As noted in the post above, you will have a problem hitting the extension stops on the shocks unless you get longer shocks than OEM.
Schiky
Awesome thank you very much guys!!
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Also get camber adjusting kit so otherwise you will eat the tires and bearings
