How's this work?
Ranger850
Doesn't get Sarcasm . . .
4,703
Tallahassee Florida
Stock 2"
Stock
I'm no 4wd expert ( I know, hard to believe ), but from what I've learned here, is that the front gears have to match the rear gears to keep things from binding up and/or breaking.
Can you guys explain what I'm seeing here and how it works. I saw this on DeathWish S2 : Mud Buggy Adventures. ( Prime )
fastpakr
2,849
Roanoke, VA
The simplest answer would be to match the differential gears to the tire size at each end so everything evens out. So lower gears in the rear axle with the larger tires, vice versa up front.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Miss matched tire sizes require miss matched gear sets.
You probably wouldn't want to drive it to town... but to sling mud/sand it works.
97RangerXLT
4,021
Fishers, IN
2"
31"
This^^^. As long as it is geared so both tires travel the same distance per revolution of the driveshaft, you are good.
AJ
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
Kinda what I thought, but wanted to ask the experts.
ericbphoto
Overlander in development
16,783
Wellford, SC
3.0L
6"
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Thats a bad ass marquis
Blmpkn
Toilet enthusiast
6,438
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Is there a season 2 of that out now? I watched it last winter.. I thought the whole southern mud buggy episode was in the first season
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
You might like Season 2 of this show. Hell, you might like the first season. Just a crew and a couple of cameras, no big production team getting false reactions and retakes. Season 2 starts with cars like that Marquis going through trails. One guy has a 4 door Buick sitting on a F-350 chassis. They also widened a old Hi-Lux 9" and put a Ford 7.3L diesel in that little truck.
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
I started S2 last night. IDK, I've been binge watching this show.
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
They probably put the Marquis on a tractor setup. It has a nice big diesel engine where the center console should be...
I'd take it to the mud bogs and run it.
Are they from FL?
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
These guys had a welder, plasma cutter, air, all kinds of stuff. Dually rear axle
Ranger850
4,703
Tallahassee Florida
Stock 2"
Stock
one guy had a Volvo that looked like a Cherokee. LS swapped with K5 Blazer running gears
