I am interested in a super chip for my 4.0 liter 2011 Ford Ranger
Kevin J. Cutcher
Toledo, Ohio
Ford Ranger 4X4
I am looking to buy a performance chip for my 2011 Ford ranger 4X4 4.0 liter engine. I am also getting a K&N air filter and FlowMaster exhaust
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
Your best approach is to use a tuner that has performance program(s) on it or have it programed. I understand chips can be problematic. The contacts can oxidize, creating a bad contact. A tuner does not have to be plugged in all the time. You just plug it in and have it reflash the computer with the new tune then unplug.
JoshT
1,798
Macon/Fort Valley, GA
That's cool, so what is the question?
I'm not going to say either way on chip vs tuner. Tuners work as @gw33gp said. There have been a lot of chips used over the years with no issues. I've used both. Tuner on my 99 when it was 4.0 and chip on my 2000 7.3L. The chip has only been installed for a few years so can't speak to long term on mine.
Haven't had a problem with either except for the tuner no being supported by the manufacturer 15 years later. Fortunately I think I Still ahve the old versions of the software that go with it squirreled away on a drive somewhere, but I haven;t tried to see if they will sork on a modern OS or if I'd need to find a workaround (virtual machine or revive an old PC). Would love to be able to use the same tuner with new tunes for the 5.0L swap, but I haven't tried to see if anyone can still work with it.
rubydist
865
Denver
Ford Ranger FX4
You would get the same performance gain by just sending me the money and letting me gamble it away. Seriously. Off the shelf tunes have a bad reputation for a reason. Very few of them do anything useful.
Kevin J. Cutcher
Toledo, Ohio
Ford Ranger 4X4
I had a 1991 Camaro 3.1 liter and used a performance chip with good results. No problems and definitely increased HP. I'm not looking to spend hundreds of dollars on a tuner if I can get a performance chip for much cheaper and still get good results. I came to this site to buy a performance chip not discuss what the best way to increase HP. I'm going to buy a performance chip if available. I just have to locate one. All have a good night and thanks for everyone's comments,
JoshT
1,798
I'll respectfully disagree. As said above, I had a tuner in my '99 4.0L OHV Ranger and dad had one in his '00 4.0L SOHC Ranger. I can't say how much of a difference it made in the engine performance though it did feel like it had a bit more pep with the tuner installed. Bigger thing for both was improved transmission shift points. The shift improvement alone was worth the price of admission. Granted those were purchased over 15 years ago, so I'm sure the price of admission was lower then.
The one in the F-250 diesel has it running much better, has dyno proven (by users, not the tuner) results, and a very big following for a reason. It's also got other features that are beneficial for the application and an excellent platform for installing custom tunes if ever needed.
Far as I know Jim doesn't sell performance chips or tuners and I haven't seen them pop up much in the for sale section. You probably aren't going to have much luck buying one here. Your best chance at getting a used one here is to post a wanted ad in the parts for sale section of the forum. If do that you will probably get a few scammers try to get you to buy one from someone they know offsite, so check out the person's site activity before you trust them. The moderators do a good job of filtering those people out, but some still get through.
Also be forewarned, threads often get off topic or head in a direction you may not have wanted. It just happens when you post something on an open forum, especially with a group as ADD as this one. Things are going along good and SQUIRREL..
Lefty
1,877
Saint Paul, MN
Ranger Edge
I have a performance chip. It doesn't really do much.
superj
2,659
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
they make one for our 3.0?
i guess since mine is a stick, i never thought about it needing one because of the tire shredding power available as soon as i push the gas pedal
rusty ol ranger
2.9 Mafia-Don
7,616
Michigan
177 CID
You must have it confused with a 2.9
