I have a 1990 ford ranger and i swapped a manual in
bradley899
4
Georgia
Ford ranger sxt
I swapped a manual transmission in my 1990 ford ranger 4.0 sxt and I'm having trouble with the wiring please help. Tha k you
Josh B
1,986
Oklahoma
Hey Bradley, welcome to TRS , someone will know what you need to do with the wiring
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Which wires? Maybe pics would help...
Josh B
1,986
Oklahoma
Are you referring to an electric shifter?
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Ranger: 2.9; BroncoII: 4.0
You need a reverse light pigtail and then you splice that into two of the wires(purple/orange and black/pink) that come out of the 5-pin connector at the trans. One is nothing to worry about, and the other two( I don't recall off-hand the colors) are the neutral safety switch(If you plug them in you will only be able to start the the thing in neutral.)
See page one
bradley899
4
Georgia
Ford ranger sxt
The transmission is from a 2004 ford ranger. There are plugs on the transmission are different and wires still hanging down i don't know if I just tuck them away?. Also they key doesn't work i have to jump the ignition relay to start and still it will crank sometimes but run horrible and backfire out of the intake. And I think it has so.sthing to do electrical i don't know what to bypass. Thank you
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Did the engine run fine before you put the manual in?
bradley899
4
Georgia
Ford ranger sxt
Its a badass truck the motorr was just rebuilt its Makes crazy noise out of the intake
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
How many wires is there coming from the front and how many plugs does the transmission have?
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Did you use the engine with the automatic after it was rebuilt?
bradley899
4
Georgia
Ford ranger sxt
Yes the automatic before I put the
Manual in was and I don't know where the nss pig tail is to bypass
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
If it had the a4ld, the nss wires are in the five-pin plug that went to the automatic.
bradley899
4
Georgia
Ford ranger sxt
No see I also have a 2001 transmission thats wht I wanted to put in it at first but I put the 2004 in e everything bolted up just fine e just do t know electrical
bradley899
4
Georgia
Ford ranger sxt
Can I put the 2004 throttle body on it
No members online now.
