i have a question on a dodge ram
olred90
Dover, Pa/Williamsport, PA
hi everyone,
the horn on my ram isn't working. i've tested it just connecting wires to the harness on the horn and touching the battery and it works. i'm going to try the fuse, but on the panel, there's no specific horn fuse. does anyone know under what cluster it's found in. the guy at advance said it could be under the cigarette lighter or the radio. what do you guys think?
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
does it have an airbag? usually when the horn quits working and the airbag light is on it is an issue with the clock spring needing replaced.
olred90
its a 94, and yes it has an airbag and now that you mention it i think the airbag light is on
tanbuddy
Poconos, Pa
its one of the relays under the hood behind the battery. Its in the manual somewhere
TS6034
September 2009 STOM Winner
MTOTM Winner
Northern Michigan
306
More than likely the clockspring is bad.
Spent many years at the Dodge dealer. Saw it many times...
Just my .02
Redjosh
finlayson mn
1996 and 2008
dodge
i wouldn't bother with it unless you really need a horn
bikerboy
Lancaster,PA
most likely a clock spring as previous mentioned. You could always run a horn button and mount it on your dash so you'd still have a functional horn. Or replace the clock spring to fix it right.
jaymegriffiths
7
Regina,Saskatchewan
if ur gonna redneck it make it on a pullstring like a trucker that would b sick
