I need some advice on carb
87ranger2.0
Nashville tn
2.0
K I got 87 2.0 with a motorcraft e77e-9510-aa 2 brl carb.is that a good carb? Should I rebuild it n where can I find a rebuild kit for it.if it's not worth rebuilding what other carb could I use w/o needing exp mods.I'm looking for a bolt on n play carb.
kimcrwbr1
46
maplevalley WA
2.8l
As long as the throttle butterfly shaft is good and it comes apart easy a rebuild kit couldnt hurt. Take it apart on a bench keeping all the gaskets and rubber pieces and screws in order you took it apart including jets. Get a gallon of carb cleaner or enough to soak it overnite in a bucket. blow all the ports out good with water and then follow with air pressure. The carb kit will have extra parts so match the ones you have with the ones out of the kit so your not worried about what you missed. Be careful take your time adjusting the float and read the instructions a good repair manual for your truck couldnt hurt. I got my last one at the bone yard for $5. Lay everything on the bench in order so it is easy to put back together. Any Qs just as someone here can help. GL
87ranger2.0
Nashville tn
2.0
Thats what I was leaning towards rebuilding it.k now I've looked all over but I can't fine a rebuild kit for it.how much fuel pressure can this carb handle
