Identifying Positive + Negative Speaker Wires
fastpakr
2,845
Roanoke, VA
Either the voltmeter suggestion or looking at wire colors at the speaker will answer your question with no ambiguity.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
50/50 chance of guessing the right colors. If you get it wrong the first try, 100% chance on the 2nd try.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
fastpakr
2,845
Roanoke, VA
Now that we've sorted through all this... What are you trying to do?
fastpakr
2,845
Roanoke, VA
You shouldn't need the wire colors for the radio if you're using a proper adapter harness. Also - if you plug in the adapter to the factory wiring, you'd be able to immediately see what crosses to each factory wire from the labeled wires on the adapter.
