Ignition Wire for Electric Fan Relay.
gungfudan
19
Mississippi
Mazda
N/A
N/A
I am outside at this moment trying to hook up the the fan relay to the ignition but don’t know which wire. 94 Mazda B3000.
8,370
IAC Valve gets 12v with key on, as does MAF sensor heater, it would be the Red wire on either
Both are powered by EEC(PCM) Fuse(#4, 30amp) thru the EEC Relay closing with key on
Relay only draws .3amp so OK to add to any circuit
gungfudan
19
Mississippi
Mazda
N/A
N/A
So you are saying just hook on the sensor wiring?
ericbphoto
Overlander in development
16,603
Wellford, SC
3.0L
6"
Yes. But only to energize the coil of the relay. The power for the fan itself should come from it's own fused 12v supply.
This message composed solely of recycled electrons. Go green!
kimcrwbr1
46
maplevalley WA
2.8l
Use the eec relay for the fan relay coil and wire the fan power directly from the battery with a inline fuse at the power dist box terminal from the battery.
8,370
Yes, to the above, eric and kim
If you want the relay to activate, close, when key is on, then splice into one of those Red wires, and hook it to relays coil(85 or 86)
Assuming relay's coil is also grounded(85 or 86), it will activate with key on and deactivate with key off
