Im installing drop pivot bracket kit , not sure where this bracket goes.
gaz
671
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Gary,
Perhaps some more pics will help, I've done se eral of these lift kits and that component diesn't look familiar ..(
ericbphoto
Overlander in development
16,667
Wellford, SC
6"
What brand kit?
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
If you're under the vehicle looking forward, the bracket mounts to the top of the passenger TTB drop bracket and the engine cross member. The holes are already there, its supposed to help prevent front to back twist.
GaryWoz
6
Coos Bay, Oregon
Ford Ranger xlt
Thanks , that's where I thought it goes , I saw a picture n it looked like the same bracket. Now I just gotta figure out passenger side camber / castor , top of tire way in even with 2.5 + - bushing..
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
You should be able to rotate the camber adjusters with a socket. Keep the truck on the ground and adjust them that way. It allows you to get the whe
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
Sorry about that. It allows you to align the wheels pretty accurately, it's cheating, but it works. I have zero tire wear, even with the bent TTB in my truck.
Skooby
34
Oregon
Here's a good pic
