Im new here
Cherrybomb
Pottstown,Pa
1989 and 1990
Hi everyone Im new here as i said in the title. Heres my first question. Im going to look at a 1990 Ranger 5 spd 2.3 with 90,000 miles. he says the interior is flawless and the paint is the original so its faded etc. minor dents and stuff. But it doesnt run in the ad he says timing is off. do you think the belt sliped or just gave out. And in this condition what would you say its worth since he says in the ad to make him an offer. I just dont want to buy it and end up having it be something really expensive. Heck i lucked out on the one i have now i mean its beat for interior and body whys but i got it for 400 and the guy thought it blew up. Here the stater solonoid went the same time the oil pump got cloged and the valves were tapping when he shut it off and it wouldnt start again. Plus its a 92 motor just ashame the thing is so rough i dont feel like putting money into it thats why im going to look at this one.Thanks for any advice
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
first of all welcome to the ranger station. second if the timing is off install a new belt if it jumped with the one it will do it again. i would start at $150 cause you can always go up to where you feel comfortable.
Dave R
In the snow belt
Kaiser
Normally, with decent maintenance, the 2.3's are fairly indestructable. If it has the original timing belt it's a good bet it's gone south.
Cherrybomb
Pottstown,Pa
1989 and 1990
Thanks guys. I thnk ill try to pull the cover back a little and see if i can see the belt. Ill let you know what happens. Thanks again.
Cherrybomb
Pottstown,Pa
1989 and 1990
Alright ill make this quick. Long story short timimng belt jumped off . So if i just take off the belt then set it to Tdc then put the belt on is that all i have to do.?
thanks for any info
Cherrybomb
Pottstown,Pa
1989 and 1990
Another question so the belt jumped off. I have been told the 2.3s are non-interferance motors . Is this true? Or could have the pistons hit the valves?and possible bent the valves? he turned the motor over for me but it sounded fine turning over. would i be able to hear anythying? thanks.
Jonboy
Philpot,KY
The 2.3L is a non interference motor, should have no problems. Put a NEW belt on it should be ok
baddis
6
Avon,il
2014
The 2.3 is a non interference motor should have no problems put the new belt on it should be ok
+1 on a NEW belt don't reuse the old one. you will end up in the same boat
Cherrybomb
Pottstown,Pa
1989 and 1990
Alright. cool, i read the Haynes Manual lastnight and it said about possible damage but i just wanted to check. Im pickin it up tomorrow hopefully i get time to work on it this week. the only thing i dont like about this truck is that the one coil pack is under the intake. where as on my 89 with the 92 motor both the coil packs are by the exhaust side. thanks again everyone
