Insanejughead
- Jan 7, 2008
- 33
- Missouri
- '94, '86
- Ford
- Engine Size
- 2.3T
Tonight, and after spending five hours on it, I figured out why my rear differential was leaking bad enough that it runs itself dry rather quickly.
The 8.8" that came in my ranger has always had problems with leaking, but it has progressively gotten worse over the years. At first, I started noticing fluid getting past the seals and covering my brake hardware; but after a while, the diff cover started getting wet; finally, the entire bottom half of my diff cover gasket is soaked on the outside and there is a film (that drips in places) of gear lube all over my rear undercarriage, tailgate, and rollpan.
Tonight, I went all out on checking stuff. I was almost horrified to find out that my diff was ALMOST completely dry. Earlier today, as it started making noise, I realized that I need to drive slow (15mph) as I went around my hometown.
Everything went fine until I went to check the vent tube. The rubber line was good, but I couldn't probe anything down into the axle housing to touch the axle shaft. I took several different tools to start trying to work out whatever crud may have been stuck in the vent orifice, but nothing made any progress (nail set, nail, screwdriver, drill bit by hand, self-cutting wood screw, allen wrenches). So, I took the vent orifice off, and that's when I discovered...
THERE WASN'T A HOLE GOING THROUGH IT!
For some reason, it was solid metal in the middle! Well, at least clamping it in the vise and attacking it with two different sized drill bits made it how it should've been.
However, I can't understand why the vent plug was solid?
Has anyone else had problems with their differential and thought to give the vent plug a thorough check, only to find this out?
