In search of replacement shocks.
Bill
898
Sacramento, CA
At 150K miles, my shocks are worn out! I'm looking for as close to original ride quality as I can find for a 2007 2wd. Does anyone have any suggestions other than buying Motorcraft shocks as a replacement, which I've considered? I don't like that floating feeling a lot of Monroe shocks. A little stiffer than stock is OK, but I don't want to feel every bump in the road. Has anyone installed the Rancho RS5000x (RS55222 for the 98-11 2wd)?
Frozen_Ice
4
A Galaxy far far away
3.0 L
P225/70R15
Have your pets spayed and neutered
I installed monroes shocks in front and monroes in back. Made a world of diff from Originals.
PART NUMBER: 37153 front
MONROE® LOAD ADJUSTING SHOCK ABSORBERS rear
Frozen_Ice
4
3.0 L
P225/70R15
I researched the pizz out of shocks and finally went with monroes bc the truck shop that put them on uses monroes on semi trucks, my research concluded montoes will last, if you are lifting, jumping or some other specialized activity w ur truck then maybe get a diff brand but the other brands were more expensive. I also found that shops won't install and back a warranty if they don't sell the brand.
Good luck
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Im 99% sure the OEM shocks are made by KYB on the 2wds. I used KYB excels last time and they look and drive exactly like the original "motorcrafts".
Bill
898
Sacramento, CA
The KYB shocks I got didn't look like the OEM shocks. The body of the KYB shocks were a little different, and the stem was shorter with a different thread. The KYB shocks were made in Mexico. The OEM shocks are made in the USA. Also, Tenneco is a major supplier for Ford. Tenneco retails their shocks under the Monroe and Rancho brands. Both of those brands had shocks with the same physical dimensions as the OEM shocks. The KYB shocks are a little different.
