- Aug 7, 2007
- 543
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
I replaced the inner tie rods this weekend and was surprised to see how easy it was for the most part. I did buy the inner tie rod tool from Harbor Freight which helped a lot. Yes, you can use a pipe wrench also but you have to turn the steering all the way out and I think the force used to break it lose could potentially damage the rack and pinion. I think it is much safer to turn the steering all the way in and use the correct tool to break it loose.
The most difficult thing to do was putting the boots back on. I don't know if it is the same for 2WD but it is difficult for 4WD. I put a little lube on to help slide them place but there is not much access because it is like working in a little cave. It is hard to tell if they are fully seated once you do get them on. The right side is not too bad because there is a little access to the backside. The left side has too much stuff on the back side and very little access.
The boots have three nubs spaced around the rim and I used a dull screw driver to push on them to get the boots in place. I realized afterward that I should have made a tube with the right ID to slip over the boot to push against the nubs. That would probably have made an easy job of it. There is a vent that sticks out on the boots but a little cut out on the tube should be enough to clear that.
My kit came with metal bands to clamp the boots onto the rack and pinion housing. I have a tool to clamp those and it worked fine for the right side because of more access to the backside. The left side did not work so well. I had to improvise with some other tools and a lot of time to get it clamped. Tie straps would have been easier but I don't know how durable they would be over time.
