Installing aftermarket gauges
Awesom-O
183
BC Canada
Hey fellas. I am toying with the idea of adding some aftermarket gauges to the build. Was thinking just the basics with volts, water temp, and oil pressure. I like the more accurate/detailed reading of aftermarket gauges, but definitely don’t want the OEM gauges to be inert in the dash. I am running a 91 4.0 OHV and was wondering of those that have done it or are also considering it, where they best installed the sensors for oil and water temp for a clean instal, while keeping the OEM units functioning. Was thinking of these electric Auto Meters.
Cheers.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I went with oil filter sandwich adaptor and a hose adaptor fir temp. I've used Glow Shift adaptors... get them on Amazon.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I like Autometer gauges but prefer to mount them in the dash and eliminate the factory gauges rather than have duplicates. It's more work but it looks way more finished and it puts them where they're easy to see, not below the dash. I also buy gauges with letters, pointers, and backgrounds colored like the originals.
There's no such thing as anal- that's what the slobs call someone who is meticulous and particular.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Attention to detail makes the best results.
Terry
19
Gardnerville, Nevada
2.9
I run a direct oil pressure gauge. Don't trust electric. I would love to see how you mounted gauges in the dash, any pics?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
They make fittings that you can splice/clamp into hoses that are threaded. I ran a temporary temp gauge when I was deling w/ some cooling issues...pulled it when resolved...left the fitting and just plugged it in case I need it again.
svtcards
137
Lyman maine
302
3'' front 4''back
I agree! More work but way better looking
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Do you guys run all new wiring or do you splice into existing gauge wires?
What's it like installing an aftermarket tach when its a 4.0OHV coil pack?
Asking for a friend...
Awesom-O
183
BC Canada
look no further than the tech article in this very site. 😃
No members online now.
