Interior swap
Tonytitan
Nashville TN
I have a '98, very vanilla, no power options Ranger. There is a '99 wrecked Ranger with full power doors and a full black interior available that I want to swap into/onto mine. If it's other than just a straight dismantle/reassamble swap, what issues am I facing?
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Hi Tony and welcome to TRS~!
As long as they are both the same cab style (reg vs ext) then it should be a direct swap since the cabs from 98 up are similar.
The only thing you may need to change is the harness that runs to the doors to power the windows and locks but I think they pre-wired everything in so they could outfit any options...but I could be wrong.
Thing to do would be to get the whole truck and then you can swap whatever you want as needed.
The only thing you really need to be careful about is the PATS (passive anti-theft system) but if you ware swapping in the whole dash that would fix it all in one shot...this was installed on Rangers built between 1998-2001 so those two years (99 and 98) are in that group.
If you run into problems there are ways to work around them...but the best thing is to swap out everything needed like the dash and the steering column...but if you are swapping interiors to make them a different colour then that would be part of the swap anyway.
I couldn't find anything in the Tech Articles on this but you can learn more from the following link:
http://www.explorerforum.com/forums/index.php?threads/everything-you-wanted-to-know-about-pats.234975/
17,912
SW Iowa
I would just try to keep your swap to the shell, keep your electronics.
I know somewhere in there they monkeyed with the speedo drive too.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Oh, right...that too...I'd have to search on that one...
Another option that I don't recommend but some have done is...painting the vinyl parts.
The dash I swapped into my 88 was from a 96 and the previous owner had painted everything inside the cab. It was a pretty decent job but when I got the truck it was chipped in many places...looked really bad but he dash was still in good shape so maybe his kids were not allowed in the front seat...:)
Tonytitan
Nashville TN
If you run into problems there are ways to work around them...but the best thing is to swap out everything needed like the dash and the steering column...[/url]
I have a 5-speed. The providing truck is an automatic. Not sure if has PATS active. Hadn't planed on swapping steering columns. Is this a problem?
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Not sure to be honest...probably someone more familiar with the system can answer that if it isn't in the documentation in the link.
I will have a look at the link later and see if the door locks are tied into the PATS system...that would mean you need to at least swap over the ignition cylinder and the PATS module from the column and as long as nothing was changed in that area it would be easy enough.
EDIT: That means you wouldn't have to swap the whole steering column...but that is probably the easiest part since it is bolted to the dash and there is a swivel disconnect just inside the firewall that would allow you to swap the inside parts as needed...the shift indicator may be something you can delete with a trim cover but I can't remember how that worked on mine (which is very similar to the 98 dash).
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
OK...I just read through a bit more of the comments...apparently the PATS controls the door locks and tailgate if applicable. It is also programmed into the PCM of each truck so you would probably need to swap that part also...but there may be a compatibilty issue with the PCM because I have seen where there can be one PCM for manuals and one for Automatics.
So in order to use anything from the other vehicle you would need to consider using the PCM, doors, tailgate and you'd need to see if the module on the steering column could be swapped over as well...or swap the entire steering column over.
A bit more work involved but...sounds like it is something that can be done. You can probably also consider just reprogramming the module on your truck to take the new keys if your old ones don't support the power options...but i don't see why they wouldn't unless the fobs are completely different...
If nobody else chimes in that can answer this more directly you might want to speak with a Ford Tech at a dealership or a locksmith...but that could cost you some money.
17,912
SW Iowa
It is a truck, you can take the tailgate off and throw it in a ditch and it won't care.
I wouldn't change anymore than you have to. Being an easy to match color (black) I would just paint your steering column covers to match and leave the column alone.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
True...
Just trying to make sure the PATS parts are in place...nothing like spending all that time and finding out something was missing...and not being able to drive the truck until that is fixed.
If it was my truck I would forget the power locks/windows and just swap over the trim until I had everything figured out.
