Broosedamoose
- Mar 10, 2012
- 115
- South East Massachusettes
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
I've been having this issue for about 4-5 weeks and can't track it down! The truck will be starting fine but then I'll go to start it and it won't crank. Let it be for a bit and it will crank. No rhyme or reason to it. Does it when it's cold, does it when it's warmed up and it doesn't matter what the outside temp is. It hasn't happened for a couple weeks now but I used the truck all day yesterday and it was fine. Went to start it today and it won't crank. The last time it happened I drove to my doctors, went in and when I came out, it wouldn't start! Had it towed to the garage and it cranked as soon as he tried it! Thought it may have been the Neutral Safety switch so we replaced it. It's been fine for a couple weeks but I just went to leave and it won't crank! The starter was replaced about four months ago. It's not the PATS. Battery has 12.4V. I can hear the relay at the passanger side kick panel clicking when I turn the key. I'm not sure what else it could be. Of course my mechanic is on vaccation until the 26th. Any ideas?
