Is there a way to bench test the fuel gauge?
TIGGER
Beaverton, Oregon
The gas gauge on our 91 Explorer hasn't worked for over a year now and the wife wants it fixed. I ground out the yellow wire and the gauge did not peg so I assume it is the gauge or a wiring problem. Is there a way to check the gauge on the bench if I pull it from the cluster?
rtg143
ASE Certified Tech
61
Oregon
5.4l
It may be the anti-slosh module too. Here's the wiring diagram for it.
[/IMG]
TIGGER
Beaverton, Oregon
Is the anti slosh module the circuit board on the side of the instrument cluster?
kimcrwbr1
46
maplevalley WA
2.8l
find the wire going to the fuel guage with the key on, a pulsing voltage to it usually about 8 volts pulsing and touch it to ground if the guage goes to full the guage is working the sender controls the ground goin to the guage.
TIGGER
Beaverton, Oregon
I went to the wrecking yard and got a slosh module from another rig. I installed it and the fuel gauge is working again:icon_cheers: I made sure to grab one from a rig that did not have the needle pegged on empty.
thanks for the help guys
rtg143
ASE Certified Tech
61
Oregon
5.4l
Glad you got it fixed. Thanks for the update.
