Is this the knock sensor?
komoto123
Kentucky
2.8 v6
Is this the knock sensor? I pulled it from above the starter, on the right side of the engine. If it is, what do i do with it now that my computer is gone due to duraspark conversion.
kimcrwbr1
46
maplevalley WA
2.8l
If it still works give it to someone who needs it they are real hard to find. Yes that is the knock senser.
komoto123
Kentucky
2.8 v6
Alright whoever wants it can have it. I have the connectors with it as well.
I still need to know what to do with the hole it came out of though.
kimcrwbr1
46
maplevalley WA
2.8l
Nothing I dont believe it goes through?
drsvox
Prattville, AL
V6 2.8L
how much you want for it?
I replaced my old sensor w/ an aftermarket by matching thread size and connector, but i'm not sure yet whether it will do the job and my restoration is stock.
and yes, don't worry about the hole...it does not go through.
kimcrwbr1
46
maplevalley WA
2.8l
FYI to test the knock senser bring the engine up to normal temp and connect the timing light up to #1 plug wire and shine it at the timing marks, have someone tap on the block next to the knock senser and the timing should retard with the tapping
. Do not tap on the senser they are brittle.
3,614
Sensor.
drsvox
Prattville, AL
V6 2.8L
thanks kim...gotta get the dang this started first. I am almost at my wit's end.
engine (rebuilt) is getting spark and fuel (and I'm pretty sure air), turns over, backfires thru the carb, but just won't start.
valve clearances were set and rechecked during build, and I'm certain firing order is correct.
guess i'll start walking thru everything, again... :annoyed:
komoto123
Kentucky
2.8 v6
I never checked whether it went through anything. I had the front end jacked up so i just assumed it didn't pour oil because of that. I'll check to make sure tomorrow. If it doesn't go through anything i will just leave it as is.
Let me check to make sure the hole doesn't go anywhere and then you can PM me and i'll send it to you for free. Provided shipping isn't to expensive.
rangerin
North Carolina
2.8
If it doesn't go through the block, I can send mine to someone as well. Just Durasparked and it's still in the block.
AndyB.
148
Cincinnati, OH
You removed the sensor and the adaptor. The hex portion, which screws into the block, is a separate piece from the sensor. You could unscrew the sensor and replace the adaptor into the block.
enginepaul
12
Northern California
2.8
Never saw a two piece knock sensor. I also never saw the threads go all the way through.
komoto123
Kentucky
2.8 v6
I don't know if that is sarcasm or not, but i asked the question because i didn't know.
I did not know this. I might just do that.
