honhon
- Jan 5, 2013
- 0
- Ford
hey all... i searched for my 4wd not engaging and i fixed that issue... i took my shift motor apart cleaned up the brush contacts and re-greased the worm gear and the end of the motor shaft re-assembled it and the truck shifts in to 4HI now...
but it wont go into 4 LO... it just clicks a few times and it dis-engages 4wd all together.
i went outside just a minute ago to double check to make sure im doing everything correctly...
transmission is in neutral and i have the brake on and even the parking brake.
i havent been doing my tests with the truck running because i assume sinse its just going off of position of the tranny and the gear shift i wouldnt assume it needs to be running...
i also put the tranny into gear and hit the 4 LO button and it just blinks... i am assuming its looking for the tranny to be in neutral and when i put the tranny into neutral with my foot on the brake, it does its normal thing of clicking and then just dis-engages 4wd all together...
anyone have any ideas? i was thinking maybe that sensor thats wired into the motor... only thing ive come accross is the transmission range selector sensor...
but that search only nets the part thats attached to the tranny not the small push in sensor thats wired in with the shift motor.
thank you for any and all help.
