kill switch installation
dancron
NJ
Im planning on installing a kill switch in my 2005 ranger, i want to run it through the fuel inertia switch with a rocker switch. There is two wires to the switch a pink/black wire and a green/yellow wire, which one should i break to put the switch in and would a 25 amp rocker switch be enough for it? Something like this http://www.radioshack.com/product/index.jsp?productId=2062533
Rolled Ranger
Puyallup, WA
'91
I believe there is just one wire in and one wire out. You can tap into either one. It shouldn't matter. I had a full side bronco and ran around with the top off quite a bit so I did the same thing. Except I ran it through the cig lighter. I could just take the lighter out and throw it in the center console and it wouldn't run. 25 amps should be plenty.
dancron
NJ
thats a pretty awesome idea with the lighter :headbang: thanks for the info
