KYB Shock Install Question
qbnlykwhoa
07204
Hey guys, just a quick question about the installation of the KYB gas adjust shocks. The instructions are pretty useless.
Most other shocks i see have a built in nut to hold onto for removal while this one does not.
The kit comes with two nuts as seen below. Am i correct to assume that a nut goes in first all the way to the bottom fo the top shaft, then the other nut is for the top of the shaft?
I put the shock in already and didn't use the second nut and the top bushing is nice and compressed while the bottom isn't.
Just figured i'd ask and make sure before i take it all apart again. Thanks!
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is a special tool to hold the nub on the top of the shaft, both nuts go on the top and you hold the shaft with the special shock tool. One nut tightens it up, the other is there just to lock it.
The order should be large washer - bottom bushing - frame - top bushing - large washer - nut - nut.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
This is the tool.
Most parts stores have them, or google "ford shock tool".
qbnlykwhoa
07204
Thanks for the quick response. So then this looks right? Just add the second nut?
61150
ericbphoto
Overlander in development
TRS 25th Anniversary
16,778
Wellford, SC
6"
Uncle Gump
Token Old Guy
13,617
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You need to put the weight of the vehicle on the tires before tightening up the top nut.
Edit... this will get the bushings to compress equally.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Wow. I always used a small wrench or paur of pliers.
thanks
That's fine for installing them but once they get rusty and you need to take them off the tool really helps. It's only like 10 bucks.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
qbnlykwhoa
07204
Edit... this will get the bushing to compress equally.
Gotcha, had a jack stand on the jack point on the lower arm during install but will check it again with the tire on. Thanks
qbnlykwhoa
07204
Thank you! much appreciated.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Tighten only until the bushings are squished to the same size as the washers.
pjtoledo
3,015
Toledo Ohio
Fords
3.0 2.3
the tool is a double D socket.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Costs the same as the actual tool with both the top and bottom though... :dunno:
I got mine for 8 dollars and it has 4 different shock tip sizes. The tool just works better lol.
pjtoledo
3,015
Toledo Ohio
Fords
3.0 2.3
I mostly threw that out for the "double D" part.
can't imagine why :woot:
