gdk771
- Apr 26, 2008
- 0
- georgia
- Ford
I have a 96 4.0 Ranger with the 4R44E transmission. I noticed when the trans was cold and engine running it showed low fluid (below the bottom hole). I added about 1/2 of a quart of Mercon V and noticed the transmission shifting odd. I then checked after driving about 30 miles and noticed it is now about 1" above the cross hatched area and top hole. I also noticed some bubbles in the fluid which I think means it is foaming. Can anyone tell me what the fluid capacity range is between the lower hole and upper hole? Also, is the level accurate after driving around 45 min or 30 miles or is this too "hot". I don't know how much I should remove now to bring it back to normal.
Thanks
Thanks
