SOLD! Last chance! Sway bar kit
Status
Not open for further replies.
laser3kw
4
(actual join date:2001) Rockford, Il
2000 3.0 / manual trans - orginial motor killed by failed CPS at 85k - r.i.p.
Thanks for the interest - item has been sold
Last chance! If it's here May 1, it goes in the scrap!
I need it gone - hate to see it wasted
New - Genuine Roush Performance Sway bar kit
Fits 1998-2005 Ford Ranger
Heavy duty front sway bar and updated rear kit.
hardware kit included
Bought new in 2003 and was never installed.
greatly improves handling
_____$100_____ or reasonable offer
can meet a TRS member in North central Illinois at a reasonable distance
70420
70421
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Interested. Can you post photos?
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
If you were willing to ship it, I'd be interested.
laser3kw
4
I will get a quote based on box dimension, buy I will need destination zip code
superj
2,735
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Wow!!! Nice set up. I guess I would like to be number2 if shipping doesn't work out for number1.
But, do those work on an edge? If not, than I am out
pjtoledo
3,020
Toledo Ohio
Fords
3.0 2.3
is the front bar for coil or torsion bar setup? stock bars have about a 2" difference for the front.
coils bars are wider to clear the spring bulges in the frame.
laser3kw
4
If you are willing to lend expertise, I will get some measurements and we can figure it out. The original invoice says " Roush sway bar kit - 1998-2005 Ranger" and that's it.
75152
pjtoledo
3,020
Toledo Ohio
Fords
3.0 2.3
I'll hide some Easter eggs under my Rangers tomorrow as an excuse to do some measuring.
pjtoledo
3,020
Toledo Ohio
Fords
3.0 2.3
measured from the bottom of the links, corrected because the links are not true verticle.
2000 torsion bar system about 40 inches
2005 coil system about 42 inches
that would be between the centers of the holes.
from previous experience the short bar will hit the frame bulges on coil trucks ( 98-11 )
the long bar on the torsion frames will put the links at an increased angle, user discretion.
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
laser3kw
4
Attached photos show approx 42-1/4"
The front bar has a Ford part number on it and a search will show the Ford model / years it fit. #F87Z-5482-DA
The rear has a Ford part number but a search turns up nothing. #E92A-5A771-AA. It might be a Ford / Rouse part number, IDK.
shipping box is 47" x 12" x 8" and weighs an estimated 45 lbs. Shipped from 61109. Estimate to 26101 would be about $50
75259
75260
75285
75286
75287
O No 3.0!
63
Knoxville Tn
Ranger xl 3.0
I know the rear will fit, but will the front fit a 97 2wd?
Status
