Leaf springs
ff2024
Ok I have a 99 XLT 4.0 Ranger and here is the deal. I see that JC Whitney sells 5 leaf heavy duty leaf springs for my Ranger for like $186 a piece. Is this cost effective or is a junkyard swap more reasonable and if so what will fit my Ranger? I have to leave it up to the experts here since this is all a little new to me.
Thanks
Wicked_Sludge
43
Westport, WA
3-point-GO
im not a fan of jcwhitney for vital parts such as suspension components. their parts tend to be a little...ahh...low quality.
if you want heavy duty, the springs off of an explorer are stiffer and will give you a small lift in the rear. you could also build your own pack out of 2 ranger packs to achieve the ride height and stiffness you want.
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
What do you need new leafs for?
lift? stock replacement?
ff2024
I wanted new leafs just for a little more weight capacity...not much but I will be hauling a lot of dirt and rocks.
JohnnyO
Moderator Emeritus
2,873
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Often JC has name brand stuff, they just don't tell you what brand it is in the catalog. Only thing, I'd make sure that they are in fact heavier than your stock springs. There was a factory HD rear spring on a lot of Rangers also, so you might find one in a junkyard. Or use the Explorer springs.
brendank
It's only money...
Personally I would just throw in a long add a leaf. That would make it squat less under load. Plus they're alot cheaper than a new set of leafs, and you won't waste your old set.
