lean bank code help (176)
Jackson, New Jersey
im currently getting a lean bank 2 code on my 94 4.0. i was getting the code just before i put a set of pace setter headers in and am still getting it with the headers and new o2 sensors. tried clearing the codes and it just came back within 10 miles. also went over most of the vacuum lines i could get to and they were good :annoyed: any input would be appreciated, oh also replaced the the fuel filter about 800 miles ago. wondering where i should go next, injector rebuild, fuel pump?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
It is usually a vacuum or intake gasket leak.
holyford86
Some guy with a problem
656
Plattsburgh, NY
many
33x12.50R15
I've seen some of the contacts inside the o2 sensor plugs push into the plug and cause lean codes from a bad connection as well.
