- Oct 10, 2010
- 16
- Near St. Louis MO on the IL side
- Ford
- Engine Size
- 4.0
I’ve been doing quite a bit of reading (here and on pirate) about what people are (or have) used for higher volume/pressure Power Steering pumps. Unfortunately, there seems to be quite a few gaps in the information that is turning up in my searches. I’d like to fill some of those gaps for my own selfish reasons.
Where I’m currently at is that my stock Ford setup ('94 4.0 Stock Ford Pump, Box, and an added cooler) are barely adequate on the trail. When the font end locked up with my Detroit, it was a bear to get it to turn (I could still turn, but It got old after awhile, this is also rocking 37” tall tires). With my new lunch box in the front, I’m sure that it’ll be worse as the Spartan locker seems to want to lock up tighter/sooner than the Detroit did.
For simplicity sake, I’d like to try to make things work without going down the hydro assist road. If it turns out I need to do hydro assist to get to where I want to be, then so be it. But I’d much rather not add the complication as with my luck, it would just bite me in the butt later on.
Going back to the old threads, these appear to be the common options:
- Drill out the stock Ford pump for more flow (never see a mention of the drill size?)
- Cardone 20-6244 pump, which has been discontinued for some time now.
- Saginaw style pump, which requires bracket modifications to work, or a new bracket built if you can’t find the horseshoe shaped bracket. If anyone has the measurements for the horseshoe bracket, I’d love to have those.
- AGR sells a direct replacement pump that puts out 1500 psi (stock is in the 1100 psi range). However, the rep I spoke with mentioned that this pump probably would not have enough volume to handle a hydro assist setup. So this could be money wasted if I were to step up to hydro assist and needed another pump. Going by the recent threads I’m finding, there may be some quality issues with the AGR pumps, and it may not be that much of an upgrade over stock either.
- I need to put a phone call into PSC tomorrow, but it appears that they might have the horseshoe brackets we need to rock the Saginaw style of pumps (link).
As I mentioned before, I’d like to use over the counter stuff as much as possible as the ‘custom’ stuff seems to bite me when I’m out in the middle of nowhere. I’d settle for a little less power, if it means I can pick up the parts in BFE if need be.
Am I over looking any other options?
What setup are you running, and how do you like it?
