Level kit and tires!
JGrant
Law Enforcement
4
South Carolina
2.3 EcoBoost
4Cyl - 2.3 EcoBoost
Just bought my Ranger and love it! But I cannot stand the factory rake and would like larger A/T. I definitely want it as level as possible and I’ve seen a lot of 2.5” and 3”. Is 2.5” enough to level? Looking to put 265/70’s on it with my factory 17’s. I’m looking specifically into the MaxTrac 2.5 level with 1.5” spacers. Will this level and allow enough clearance?? Thanks!
Blmpkn
Toilet enthusiast
6,428
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Take a tape and measure from the ground to the middle of the wheel arch in the front and back, the difference between the two is what you want as far as sizing.
Can't help on tires. Someone else can though.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,832
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The site owner posted a thread on the available leveling kits.
As far as tires, he found that 265/70R17 was pretty much the max with the OEM wheels and suspension clearance. He ran Cooper STTs on an extensive trail run across the US and was very happy with them.
RVA Overland
7
Richmond, VA
Ranger XLT
2.3 EcoBoost
2.3
2.5" Level
2.5 will get you close. I have the 2.5 and if I wanted perfectly level would have had to go with the 3. Since I tow occasionally and have weight in the rear, the 2.5 is perfect. the tires should no be an issue with the 2.5 level in place.
e010740
15
Chandler AZ
2.3 EcoBoost
2.3
3 inch Ready lift kit with LT285/60R18 tires. I did add the one inch block in the back as well. SKU: 69-2930 for your referance. offset is 18MM.
