Lift Keys. yes or no?
adam83094
"The O" North Carolina
Mazda
thinking about lifting my 99 mazda. Should i use lift keys or take some other route? just looking some other opinions or expierences. Preciate whatever you got!
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Add more preload to the factory torsion bars. Check out the tech library for more info.
adam83094
Mazda
yeaa i thought about that but i dont want a rough ride and ive heard of some people having VERY bad expierences with that. like breaking bolts or the actual bar when hitting a big bump. just sounds a little risky.. have you ever done it?
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Yes, I lifted my truck 1 1/2". Cranking down on the adjuster bolts too much will result in broken parts and very fast wear on CV shafts and ball joints.
When you crank the factory torsion keys, you essentially twist the rear of the shaft more. When you install "lift keys" you do the exact same thing. The only difference is you spend $100 more with the keys. It will be slightly rougher, and I suggest upgrading the shocks (as it helped me out) but a 1 1/2 lift with keys or with more applied pressure to the stockers will result in the same appearance, ride quality, ect...
adam83094
Mazda
ill look under the truck when i get some time and check to see how much tighter i can go. (i dont know if the previous owner did anything) i dont think he did though since he was an old man haha. but thanks alot bud!
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Don't waste money on keys.
Twisting your torsions, or using keys it gonna ride more rough than stock. Nature of the beast b/c either method is achieving the same thing (one just is better at depleting your wallet).
If you can live with a bit more rough of a ride *hey its a truck remember?* twist 'em, and have an alignment done. Nextel. Done.
rangeron31s
Grafton, WV
4 liter
i agree dont buy keys just crank them alittle
B-MAN
St. John's
X2..
running keys for about 2 months now…feels like your riding on a bed frame
