lift question
ltuck808
portland oregon
2.9
I just did a 2 inch coil spacer on my bII and now with my bigger tires it pulls all over the plqce like the roads have ruts. My aligbment is off a bit. If I switch lanes or hit the paint at all it just jams to that side. Maybe my tires are toed in..would that cause this? Any info please help. I also ordered brand new upper and lower ball joints for both sides. Please give any info! thanks
Anytime you raise or lower a vehicle it affects the steering and the way your tires wear.
I'm not sure if a 2 inch suspension lift requires additional modifications such as longer tie rods or not.
Someone else will have to answer that. If not, just take it to a alignment shop and they will striaghten everything for you.
chrwilkins30
6
Mishawaka, Indiana
2.9
you need camber bushings and a alignment. other wise say bye-bye tires. you'd be lucky for them to last 5000 miles with a spacer to be installed on a ttb.
ltuck808
portland oregon
2.9
I'm not worried about tires I'm worried about how it drives
4.0B2
151
Walls, MS
4.0 v6
Get it aligned.. That'll help.
Wider tires seem to "walk" a little more when hitting ruts also. Mine used to pull a little when hitting groves in the road; but I don't notice it to much now. After a good alignment it helped a lot.
