Lifter noise
Barbara
6
Michigan
Ford ranger
Hey everybody my 1985 ranger v6 2.8 litre is making really loud annoying lifter sounds. What's the best additive to help quiet them ty
duffy
19
Hot Springs, SD
Ford Bronco II
Barr's used to make a product called "Lifter Quiet" that was good but I haven't seen any in quite a few years.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,783
Wellford, SC
3.0L
6"
Would it be better to fix the lifters instead of hiding the noise? How noisy are they? Some engines do have a normal but of lifter noise. But if its getting loud, that’s a sign that a problem is brewing.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
2.8s need peridoic lifter adjustment.
Barbara
6
Michigan
Ford ranger
I would really like to do a valve jib but have never done one. It's really really loud. So until I can swap the motor or get qet a valve jib done I would like to quiet them tempory w seafoian or ? Udk
franklin2
1,777
Virginia
Bronco II
Most engines have hydraulic lifters that self adjust. If they get dirty and sticky or clogged, then they do not adjust properly anymore and make ticking noises. The common fix is to put a high detergent additive in the engine to loosen them and unclog them so they start working again. That is what you are talking about. But;
Your engine has solid lifters. They do not self adjust. The parts in the system do wear, and there can be too much clearance in some of the parts, making them noisy. The best way to check and possibly fix the noise is to pull the valve covers and check the clearance with feeler guages, while looking things over for something out of the ordinary. I believe it's 0.16 for the exhaust valves, and 0.14 for the intake valves cold.
duffy
19
Hot Springs, SD
Ford Bronco II
No hydraulic lifters on the 2.8's eh? Learn something new every day.....
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
No. The 2.9 i believe was the first colonge to use them.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just moved your thread to the correct forum.
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
From what Ive learned from my 2.8 is that they tend to have noisy lifters. No matter how much adjusting you do to them. Its just wear and tear. Mine sound like a 1,000 cats running around with tap dancing shoes on.
