Location of Door Lock Relay 1999 Explorer?
BillRod
Colorado Springs CO
95=4.9L Others=4.0L
Hi All
Where is the location of the Door Lock Relay on a 99 Explorer?
My Door Locks are going Crazy.
I can hear the lock motors cycling in the doors.
l disconnected the Negative Battery terminal to make it stop.
Any help would be appreciated.
Thanks!
Bill
3,614
If you have the remote keyless entry system the relays will be located with the RAP module behind an access panel in the cargo area. I think it is on the driver's side, but I'm not 100% sure of that part.
