2.3L ('83-'97) Looking for a cylinder head
block bunny
Phoenix az
Looking to source a cylinder head for a 1992 Ford Ranger and apparently they don't exist anymore. Anyone have any idea where I can go to find one?
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
What motor?
8,372
Welcome to TRS :)
Yes, need engine model, 1992 Rangers had 4 options
2.3l 4cyl
2.9l V6
3.0l V6
4.0l V6
All used different heads, and all are available as rebuilt
superj
2,659
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
I buy them from an ebay rebuilder. Never had trouble with amy rebuilder yet
block bunny
Phoenix az
Welcome to TRS :)
2.3l 4cyl
2.9l V6
3.0l V6
4.0l V6
It has a 2.3. Four cylinder casting number F26E.
superj
2,659
ranger edge
none
none
235s
Did you check ebay?
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
You can use '89-94 Ranger or I think '91-93 mustangs for heads, your casting number is '92 but there are more options... I don't remember if the intake manifold pattern changed in '95 or not, I know they changed the valve stem diameter and a couple other small things but with an assembled head that wouldn't matter much...
block bunny
Phoenix az
As I understand it, the intake ports are different. That's why I am looking for F27E head.
8,372
Article here in the 2.3l: https://www.therangerstation.com/tech_library/4cylinders.shtml
Scroll down
You will find this:
Head Variations
There are several variations on the 2.3 heads though they break down into (4) distinct types:
1) Passenger car oval port heads - 1974 - 1980 Mustang, Pinto, Fairmont, Bobcat, etc.
2) Passenger car D-port head - 1981 - 1995? T-bird, Mustang, Etc.
3) Truck round port - 1983 - 1985 Ranger
4) Truck D-port - 1989 - 2001 Ranger. The 1989 - 1994's and 1995 - 2001's have different combustion chambers and ports. It is thought that the newer head is better designed.
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
I just looked at the intake gaskets between '90 and '97 and the intake gaskets look a little different but mostly the coolant port that I believe disappeared in the redesign which would honestly be the biggest change since the heater circuit goes through that I think... honestly I don't remember where that goes...
