Looking for Brake lines...
jleas524
ASE Certified Tech
24
South Carolina
1994 Ranger, non-ABS.
I am looking for replacement brake line that goes from the master cylinder to the left front T-block.
Has anyone found these, other then in a junk yard?
I tried to make one but no success.
What have you done for a replacement?
sgtsandman
Aircraft Fuel Tank Diver
12,735
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Unless you can find a straight, pre-made piece that is about the right length and has the right ends at an auto parts store, you are pretty much stuck making your own. When I had to redo most of the brake lines on my previous Ranger, I had to make and bend my own.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,527
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I always just make mine.
The NiCop line is easier to work with then steel line.
I will also say if one rusted out... the rest aren't far behind. I always did all the lines when rust was the issue.
Josh B
1,987
Oklahoma
Would that "T Block" be the one they recommend to route around?
Uncle Gump
Token Old Guy
13,527
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've always just plumbed that t-block that mounts on the driver spring bucket back into the brake system. Didn't know taking it out was a thing? You would still have to have a T to get fluid to the passenger wheel.
Josh B
1,987
Oklahoma
Ahh, T-Block had me thinking it was that block of mishmash behind the left steering inside the frame rail that usually gets stopped up
2 bronco 11s
66
kentucky
ford bronco 11
Try sstubes they list several 94-97.
