Loss of power
J.Incognito
4
Austin
Ford ranger
Hey guys I have an '85 ranger 2.0 and I have been slowly learning and rebuilding it. Well last year my truck stopped running and I thought it was a transmission or clutch problem until a year later I got on here and found out it was the shifter linkage and was directed to where to get the appropriate part. So here I am a year later and my truck wouldn't start. It wasn't getting spark. 2 weeks and much headache later it starts and runs beautifully but has not power amd I even lose power switching it into 3rd. Start losing speed. I am so frustrated and would appreciate some help.
JoshT
1,782
Macon/Fort Valley, GA
Like I said in the other thrtead, you'll get better help in the other section of the forum. I wrongly assumed 2.8L, but this has all been hashed out for the 4 cylinders as well. As there and I'm sure you'll get good responses that help you get things sorted quickly.
tw205
Bronco II Rancher.
978
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
What did you do to get it running with the no spark issue. Has the timing been compromised? What kind of fuel pressure are you getting?
8,372
Gasoline in a vehicle gas tank last 5 to 6 months, the "go juice" part evaporates and you are left with "maybe go juice"
After a year you are way past "gasoline" being in the tank
Even adding "fresh" fuel to what left probably won't help much
i.e. if you have a 1/4 tank of "water" adding 3/4 tank of gasoline still leaves you with a 1/4 tank of water, lol
If in doubt drain it out
Power is tied directly to Compression
2.0l uses a timing belt, which get old and can stretch or slip
Test compression in at least 2 cylinders, all 4 is best
140psi is OK but expected is 155-165psi
If in the 100-130s then replace timing belt
Spark timing will also reduce overall power, you worked on the spark system so I "assume" you also timed it?
J.Incognito
4
Austin
Ford ranger
Ok so I had the timing belt redone in a shop right before it broke down. I couldn't get it right so I had someone else do it. I also changed the fuel pump around the same time. The no spark I changed out the selinoid and the ignition coil before I had a friend and myself go through the wiring diagram to find out the wire from the coil to the module was burdened out. I also drained all of the previous gas that was in it before I refueled it. I have not had the timing redone since getting it started again, and I do not have a compression tester at this time.
J.Incognito
4
Austin
Ford ranger
Josh B
1,987
Oklahoma
you have posted the same question on 2 separate threads
8,372
I would check the spark timing
What about the exhaust system?
Exhaust restrictions reduce power same as a clogged air filter will by restricting in coming air
Do you have a vacuum gauge?
It can give you an idea of whats happening inside any gasoline engine
At idle expected vacuum is 18-21", lower means lower power, which can be from spark timing being off or low compression, clogged in take or clogged exhaust, you can test for which might be the problem with the gauge reading
