Low Coolant Temp 2.3
grassman
daleville indiana
ford ranger
Posted here several weeks ago about problem child. Had several good suggestions. Drained coolant plugged top hose and1 heater hose. Pressurised cooling system with air, leakage at outlet on t-stat housing . removed housing checked t-stat 192-195 degrees. Thought for a while. Found old Ford housing cleaned all parts. Measured from seal area to mounting flange. found replacement housing was 1/16 inch logger for t-stat. Installed old housing added water bleed out good. Let warm up t-stat warmed up to 192-196 per manual guage. seen t-stat open up. Finally got cab heat!!!! Antifreeze tomorrow and road rest. Thanks everyone for info.
8,372
