Lower Intake Fit
JerrySab
44
Los Angeles
Got my heads back from the machine shop, and am excited to get this engine back together. Among other things, the heads were decked, I'm not sure how much. I did a test fit without bolts and noticed a much wider gap between the heads and the lower intake than I was expecting. Is this gap too much? Or does getting it all torqued down to spec squeeze the mating surfaces together? That lower intake gasket also seems like there's a lot of opportunity for trouble if it doesn't seat just right.
JerrySab
44
Los Angeles
GREAT! thank you!
gaz
683
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
GREAT! thank you!
Your machinist should have asked for the lower intake manifold also. Dispite needing to fit, any time I've done heads on these, the machinist kept a grip of Al from the lower intake manifold port job.
JerrySab
44
Los Angeles
Yeah, I’m surprised as well tbh, the place has a great reputation. Either way,glad to have caught it early thanks to y’all.
  • Like
Reactions: gaz
