Lug nuts
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Just noticed this, these are lug nuts I assume stock:
Below is what is on the left rear
What's the easiest way to get 5 of the nicer looking lugs?
Blmpkn
Toilet enthusiast
6,438
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Take the ol' 4-way down to the nearest parking lot and pick the 5 shiniest ones you find.
Ranger850
Doesn't get Sarcasm . . .
4,703
Tallahassee Florida
Stock 2"
Stock
I bet they're the same lugnuts, just the ones in the 2nd pic have lost there shiny caps
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
those aren't caps they fit yer 3/4" lug wrench
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
no I don't want caps they are solid lug nuts but thank you
Roert42
5,066
Kintersville, PA
Ranger XLT
4.0 SOHC
Ford used those shitty looking ones, but with a thin sheet metal cap crimped on top. Not supposed to separate, but very common for the caps to come loose when hit with an impact. So if the ones you have are truly one piece they are aftermarket, probably whatever the parts store had.
I would just go on rock auto and buy a whole set of lug nuts so you have a set that all look the same and are the same size.
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
pretty sure those are them it looks like they are solid steel vs having an add-on cap
look at these that appear on the surface the same thing but these you can see the added cap
edit: I chatted CarID and they say those are not the same part, theirs are indeed one-piece steel (nice) vs the ones Advance shows which are obviously NOT one piece I'm getting the CarID ones
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Amazon has a good selection of lug nuts. I have bought a couple sets there for way cheaper than I have found them elsewhere.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
McGard tuff nuts are superior to all others. Cost a few bucks more but they are solid one piece, chrome and last 10 times longer. I’ve got a 12 year old set that still look brand new.
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
They do look nice in the corrosion tests. Will check them out.
4x4prepper
216
Atlanta
You are probably going to need to know your lug thread spec, 12x1.5 ?, before ordering the solid lug nuts. Measure the length of the stud sticking out so you get lug nuts long enough to properly seat, same thing if you get locking lug nuts. One time I ordered a set of locking McGard and thankfully they were cheaply made, because tightening by hand I knocked out the middle (cast) piece, which is basically non-functional. So, I had to trim a bit off a stud on each wheel.
