M50D shifter problem
AKBroncoII
My tranny is hard shifting in 3rd and 4th. What could cause this? It's stiff, like some resistance, not like worn synchros. Any help would be much appreciated. It's in a 91 explorer.
engdept
5
Charlestown, IN
2.9
have you tried bleeding the clutch?
thegoat4
6
Does it drag the same way when you try to shift back and forth with the engine off? If it does, you likely have a shift bar housing issue.
As far as bleeding the clutch, the clutch is not the problem unless it happens in all gears. Sometimes I wonder how much fluid has been wasted bleeding brakes and clutches for no good reason.
AKBroncoII
It is not a clutch problem, I know that already. It drags the same whether it's running or not. Clutch pushed in or not with engine off. Clutch pushed in with engine on. It's all the same. Any idea as to how I can fix this problem? I have another top half of an M50D that ate 1st gear. It has the older style rubber plugs in the back though. I wanted to keep the one I have that has the freeze plugs in the back that don't leak.
thegoat4
6
Well, first you need to pull the shift bar cover off and see if that's really the problem. Right now it's just a guess. Mine still has the rubber plugs and I've had no problems. But if you really want the freeze plugs, just go get some freeze plugs--they're dirt cheap. If you decided to fix the old shift bar housing rather than swap the two, you'll have to dig the plugs out anyway to get it apart.
AKBroncoII
The new shifter I have already has the freeze plugs in it. The other, old tranny that was pulled out has the rubber plugs. The rubber plugs on the old one caused all the fluid to become full of water and burn all the teeth off of first gear. If I pull it off will I be able to tell if the resistance is coming from the shifter or rail inside the tranny? The top cover looked like it comes off very easily.
racsan
4,447
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
the top cover is easily removed. i pulled the one off my rebuilt unit before i put it in the truck just to see if anything looked different inside compared to my old trans. you can silicone over the rubber plugs also if you dont want to deal with steel core plugs. there cheap and easy though. i siliconed over my steel core plugs just for peace of mind.
rboyer
4.hoe
The freeze plugs you need are either Dana #219-3052 or Dorman #555-108. I know of two local NAPA parts stores that stock the Dorman plugs, so if you have a NAPA near you they should have them in stock. It's too bad you don't live within a few miles of me or something, I bought 100 of them off of rockauto.com just because the shipping cost was HALF of what they wanted to ship a 10 pack and I think I still have over 50 of them left.
Fordsforever
Grants Pass, OR.
2.3L
What did you find out????
I have a ranger with a similar shifting problem and am interested in your findings.
AKBroncoII
I won't have time to pull the shifter cover until probably sunday. Hopefully it's not the tranny, this one just went in. I've had better luck with autos.
