M5OD Manual Swap Compatability
ozziemo27
June 2010 OTOTM Winner
18
Michigan
4.0 & 2.3
So I understand the parts list for a manual swap from a 5r55e to a M5OD but I am not 100 % sure on the compatability of some certain parts, could you guys help clarify?
this is for my 4.0 4wd 99 ranger
Parts List:
1. M50D-R1 transmission - Any 4.0 4wd 1991-2000 Ranger/Explorer
2. clutch/brake pedal assembly - Difference between ranger and explorer?? years?
3. Engine PCM - What year would work? for a manual 4.0 4x4 ranger I would assume but what year(s)?
4. Transmission wiring harness - what years?
5. Clutch kit - 4.0 4wd manual tranny 1991-2000 4.0L Ranger/Explorer
6. Flywheel - 4.0 4wd manual tranny 1991-2000 4.0L Ranger/Explorer
7. Slave Cylinder - 4.0 4wd manual tranny 1991-2000 4.0L Ranger/Explorer might as well buy a new one.
8. Clutch Master Cylinder - 4.0 4wd manual tranny 1991-2000 4.0L Ranger
9. Clutch hydraulic hose - 4.0 4wd manual tranny 1991-2000 4.0L Ranger
10. Starter - 4.0 4wd manual tranny 1991-2000 4.0L Ranger/Explorer
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
Answers:
2. Any '95+ Ranger or '95-'01 Explorer will have the same pedal assembly.
3. You need a PCM from a '99 Ranger 4.0 4x4 just to be safe. They should be easy to find.
4. Again, best to get it out of the same year Ranger as you are working on.
cocoasranger
5
south central Pa.
The number of bolt holes in the flywheel changed from 6 to 8 (I think it was in 1998) so be sure yours is the 8 bolt flywheel. I think the engine to trans plate on the auto and manual are different, so you may need one of those also.
mjonesjr
Firefighter
13
Salem, IN
It was late '97 when the flywheel bolt numbers changed.
The auto and manual plates are different.
njdriver02
16
2.3 EcoBoost
planning to swap a Mazda M50D-R1 into my 99 auto, i have a donor 2002 ranger, are there any other parts i need?, besides the pcm. thanks
