M5OD Manual Transmission in My Automatic 1987 Bronco II
Paul Heydon
Ontario
1987 Bronco II
Hi, can I use any 4x4 4l M5OD in my 1987 Bronco II? It currently has an automatic. Can I use any Ranger 4l M5OD from 1988-2011? Does it matter if it’s from a OHV 4l or SOHC 4l? Thanks for any information.
8,384
Welcome to TRS :)
Yes, 2.9l and 4.0l used same block so have same transmission bolt pattern
And same transfer case bolt pattern as well
1987 4x4 had speedometer cable on transfer case, so yes a 4x4 M5R1 from a 4.0l 1990-2011 would work, OHV and SOHC have same patterns
1998 and up transfer cases do not have speedometer cable hook up, in case it comes up
Swap article seen here: https://www.therangerstation.com/tech/fm146-to-m5od-and-complete-clutch-upgrade/
You should do the flywheel, clutch and starter motor upgrade
I think the 1987 driveshafts will still be correct length
Paul Heydon
Ontario
1987 Bronco II
Thanks Ron for all of the great information. I will send my build soon in hopes that I am on the right path.
